| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Sawzall vs. Axle Tube
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift |
#2 (permalink) |
The "Torch" blades are pretty good, but you want to be reallyimpressed, check out the Lenox Gold blades. They are bimetal with the gold titanium nitride coating on the teeth.
Sawzalls actually do pretty well with thicker metal like the axle tube...the key is to have at least 5 teeth in the cut, but no more than 9, so pick the teeth per inch depending on how thick the material you're cutting is.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#3 (permalink) |
I'll have to remember to try those "gold" blades. I usually use "Fire and Rescue" or "demolition" blades just for their thickness and blade life (I have a bad habit of bending blades)
__________________
1988 4x4 Pickup ISR/Battery-Intake Swap/216"c" Cam/ EGR removal/ |
| Tags |
| 44, axle, cut, cutting, dana, removal, sawzall, tube |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| IFS axle tube torx bolts..... | 4WDarren | 86-95 Trucks & 4Runners | 9 | 02-17-2008 12:28 PM |
| Cleaning my axle tube. | Stomis | The Fab Shop | 19 | 04-11-2007 07:34 PM |
| bent axle tube? | 94banshee | The Fab Shop | 10 | 01-11-2007 10:09 AM |
| 94 4runner front axle tube seal | Worley | 86-95 Trucks & 4Runners | 0 | 04-05-2006 12:44 PM |
| Kustom upholstery & chrome tube axle! | butnut | Off Topic Talk | 3 | 08-25-2002 02:24 PM |
