Need a shop compressor! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-24-2008, 09:46 PM   #1 (permalink)
OSU4Runner's Avatar
Send a message via AIM to OSU4Runner
So I've been stocking up on some new tools, and I'm going to be purchasing an impact wrench and a few other air tools soon. What size compressor should I be looking at to run? I'll only be doing light maintenance. How many HP/gallon tank should I get?
__________________
2006 Tacoma SR5 - Stock for now
2000 4Runner Limited
16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~SS 1.2 Lift~1st Gen Roll Bar~Surco Safari Rack~ Trail Gear Sliders~Deckplate Mod w/ True Flow~Satoshi Grille~Hayden 1678 Aux Cooler~Safari Snorkel and a bunch of other crap.....
OSU4Runner is offline
Old 08-25-2008, 05:48 AM   #2 (permalink)
toytech76's Avatar
I got a craftsman 27 gal compressor. It works good, I just wish it was bigger since it kicks on alot. I do use it for more than light maint. Usually quite a bit of heavy duty stuff. They are usually about $299. Sometimes they go on sale for $249. I believe they are 1/3 hp
__________________
97 Runner. 4" Pro Comp IFS lift in the front, LC coils and shocks in the rear, 33x12.5/15 Pro Comp mud terrains, 15x8 Pro Comp 1069 alloys, 00 runner headlites, clear corners and bumper lenses, 00 runner airbox/MAF conversion, Reverse indiglo gauges, 5000K HID's, LC hood struts, Magnaflow exhaust, custom grill insert, hella driving lights converted into headlight highbeams, retrofitted avalon homelink sunvisor.
toytech76 is offline
Old 08-25-2008, 06:45 AM   #3 (permalink)
CJM
CJM's Avatar
Husky has a campbel hausfeld (it just says husky on it), 33 gallon that uses oil (good thing) and puts out about 6.5CFM which will run almost any tool you want for a good bit. Its like 350 bucks or so.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 08-25-2008, 01:57 PM   #4 (permalink)
OSU4Runner's Avatar
I was hoping to find something under $150....any suggestions
__________________
Old 09-03-2008, 03:40 PM   #5 (permalink)
ScottyC's Avatar
If you want the best bang for your buck. Look on Craigslist for a 60gal or 80gal used unit.
I run a 60gal dual piston Husky that I bought from Home Depot for $399. If you plan to use your tools a lot, then go big.
__________________
Scotty
http://www.addictedoffroad.com/
970-420-4198
Toyota Winch bumpers on SALE!
ScottyC is offline
Old 09-03-2008, 03:56 PM   #6 (permalink)
111db's Avatar
Send a message via MSN to 111db
I've got the same one Scotty has. If you ever paint 60gal is the way to go, not to mention it cycles much less. Mine is 220v though, which is better than 110v.
But I second looking at CL. There are usually quite a few available there at good prices.
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 09-03-2008, 04:46 PM   #7 (permalink)
86tuning's Avatar
Quote:
The bigger the better.
A 240v compressor is 2-phase and will use less current during normal operation than any 120v compressor.
A stand-up tank is better than a lay-down tank because you can drain moisture from it faster, and because the air outlet on the stand-up is higher ( = less moisture in the lines).
The size of your air fittings determines how well your air tools perform. I run a hose directly off the ball-valve on the tank (no quick-couplers) and then I run supersize air fittings on my air tools. It's like putting a bigger exhaust on your truck, it makes a big difference in flow/power output.
__________________
- Brian
84 toy pickup
mostly stock
86tuning is offline
Tags
compressor, shop
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Is Your Shop the "TOP SHOP"? alwayssmiling67 Off Road Trip Planning, Expeditions, Trips, & Events 0 06-23-2008 07:03 PM
A/C Compressor turned Air Compressor Kiff 86-95 Trucks & 4Runners 13 08-15-2007 06:59 PM
Need an A/C Compressor ? FireMan 95.5-2004 Tacomas & 96-2002 4Runners 2 04-01-2004 12:15 AM
Now THIS is a compressor... WATRD Offroad Tech 33 03-08-2004 12:03 PM
2009 InternetBrands, Inc.
