need compressor info - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Tool Time
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-23-2007, 03:45 PM   #1 (permalink)
isaac338's Avatar
I've got a little RolAir 2 or 3 gallon pancake that I've had for eons (it was my Dad's and he had it for as long as I could remember). Recently the tank rusted through and started leaking.
I found an ad on kijiji for an old campbell hausfeld two-piston compressor with no motor. I went out there tonight and ended up scoring the tank, two pumps, two pressure switches, and a regulator for fifty bucks. No idea if the tank leaks or what the internals are like, but for fifty bucks I'll deal with it. Both pumps have apparently been rebuilt (you can see new gaskets sticking out of at least one).
The guy said the tank was around 25gal, but is there a way to figure out the capacity by measuring it?
The only model numbers I could find are VT612100 and VT5108, neither of which bring up any info on Google. Anyone know anything more about this setup?
I'm either going to snag the pump and motor off the old RolAir and hook it up to this tank, or see if I can find a cheap motor to run one of the new pumps. Is there any way to figure out the HP rating I need? There's a tag that says '733RPM' somewhere..
Also, about rust on the inside of the tank - can I spray a bunch of fluid film in there and shake it all around to try to quell whatever rust is growing? The drain was open when it was stored and I don't know if that's bad or good. Will having oil inside the tank contaminate my tools (I'm thinking like sanding and possibly spraying paint somewhere down the line).
Thanks for any info (sorry for the longassed post)
__________________
1994 Xtracab pickup, 180,000km
1987 4Runner, 510,000km
isaac338 is offline
Tags
air, campbell, compressor, compressors, forum, hausfeld, info, model, rolair, vt612100
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
A/C Compressor Kaleb The Classifieds GraveYard 29 09-30-2007 03:25 AM
A/C Compressor turned Air Compressor Kiff 86-95 Trucks & 4Runners 13 08-15-2007 06:59 PM
4 runner info?? Do you have any good pages, or info offhand i can use?? Figit090 95.5-2004 Tacomas & 96-2002 4Runners 7 06-20-2004 01:26 PM
Need an A/C Compressor ? FireMan 95.5-2004 Tacomas & 96-2002 4Runners 2 04-01-2004 12:15 AM
2009 InternetBrands, Inc.
