Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
54mm socket question
I guess you could say im preparing myself for cv axle replacement. I need a 54mm socket to remove the nut. I realize thats a very big nut my question do i need the leverage of a 3/4 inch drive ratchet or is 1/2 inch drive 54mm socket good enough. I havent had money to purchase air tools so I am using good ole hand tools still. Thanks guys
P.S. whats the tourque specs supposed to be on that spindle nut?
__________________
1991 extended cab 3.0 v6 5" trail-gear sas swap 63" chevies in rear 33x12.5 cooper discoverer stt 4:88 gears with trutrac front, locked in rear warn m8000 w/arb front bumper marlin crawler rear bumper flowmaster 40 series Last edited by weakyota91 : 05-23-2007 at 05:31 PM. |
| Sponsored Links |
#2 (permalink) |
A 1/2" drive will be just fine.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k) |
#3 (permalink) |
If you're talking about the two large hub nuts with the lock washer betwixt them, you could use a 1/4 inch drive if you want. Those nuts aren't torqued very much. If you torque them too much you'll get a premature failure of the wheel bearings. If you can't find a 54mm socket, I think a 2 and 1/4 inch socket will work too. I've got one if you'll pay shipping you could borrow it and send it back.
__________________
1990 4Runner 5spd 3VZ-E on 235/75R15's 1985 4Runner 5spd 22RE on 30x9.50's I support MisterWillie. |
#4 (permalink) |
yea thats the one. Your right they do hold the wheel bearings in I shouldnt tighten them that much. Not sure what i was thinking lol. I actually will invest in one because with my wheeling i have been doing latley i will break one sooner or later and once i find out how easy it is to replace i will probly be a little more heavy on the throttle and break more than once. Thanks tho.
__________________
1991 extended cab 3.0 v6 5" trail-gear sas swap 63" chevies in rear 33x12.5 cooper discoverer stt 4:88 gears with trutrac front, locked in rear warn m8000 w/arb front bumper marlin crawler rear bumper flowmaster 40 series |
#5 (permalink) |
The socket is large but the torque is not very high:
- http://www.4crawler.com/4x4/CheapTri....shtml#Rebuild
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#6 (permalink) |
Here ya go the Wabbit has got ya covered check this out
Jim http://www.wabfab.org/products/frontaxle/frontaxle.htm |
#7 (permalink) |
It's 2 1/8".
__________________
#8 (permalink) |
Thanks guys i definetly will get the one off Wab Fab i like the idea that is a 3/8 drive.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Non-toyota, removing 54mm nut | drguitarum2005 | Off Topic Talk | 24 | 06-12-2007 09:35 PM |
| Where do you get a 2 1/8" socket? | Asha'man | General Vehicle Related Topics (Non Year Related) | 14 | 03-03-2006 09:18 AM |
| 54MM Socket | fpkelly | Offroad Tech | 25 | 12-15-2004 10:21 PM |
| 54mm socket needed! | Ilovemountains | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 11-10-2004 10:14 AM |
