1993 3.0 engine for sale
1 have 3.0 engine out of a 1991 4-runner. Went to survey the motor the other day and found a piece of the block that had broken off in the back of the truck. So I guess the block is no good. But any of the other parts are for sale. Heads, lower intake plenum, exhaust manifolds,water pump, oil pan, valve covers, timing cover, internals, motor mounts. If you need anything else, just ask and I will see if it is still attached. pricing will vary, but nothing will cost more than $25. shipping to be paid by buyer. Actually I will take $25 for the heads assembled, and $10 each for anything else.
Did any coolant get into the oil? IE, how long did the leak exist before the engine was shut down?
Also, could you get a shipping to 28277?
The motor was shut down almost immediately. I will drain the oil tonight and see how much water is in it and work on a shipping quote.
