putting in the chevy leafs
Old Jul 17, 2006 | 10:31 AM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
I finally got the rusted hardware free and am in the process of swapping in the chevy leafs (bolt in, the new mounts/shackles already exist). the previous owner did this swap and gave me the chevys and their overloads. i got the truck with the stock leafs in. my question is...should i put the overloads in the packs or leave them out? what are the dis/advantages of them? and noob question...which direction would be the best for the overloads if i did add them to the pack? meaning, should the concave side of the arch of the overload be facing down, toward the ground, or up, toward the truck? thanks!
PS: i am tyring to MINIMIZE the amount of lift I get in the rear. my truck sits level as it is right now on the super flat stock springs. i know the rear end will come up some, but i will be putting them on a shorter shackle for now to see just how much it makes the rear end higher. if the overload would raise the rear even more and i can safely run without it, then i should do that.
Old Jul 17, 2006 | 10:40 AM
Intrepid's Avatar
If you want to minimize lift then use a short shackle, possibly the stock one and do not use the overload.
Old Jul 17, 2006 | 10:41 AM
the stock shackle will not fit as the chevys are i think .5" wider than stock. i have some pieces of metal to be used as shackles. there are 2 holes for the frame side...i will be using the one that will make the shackle shorter. is it safe to go without the overloads?
Old Jul 17, 2006 | 11:03 AM
Intrepid's Avatar
Oh yeah, good point, forgot about the width. Oh well, just use stock length shackles then.
It is safe to run without the overloads.
I believe stock those overloads curve up with the arch of the spring on a chevy. Just FYI.
88sasturbotoy
Jan 30, 2026 01:57 PM
Nickdigg
Jul 7, 2015 06:04 AM
skoti89
Jul 6, 2015 07:45 PM
wilbertd
Jul 6, 2015 07:39 AM
