FJ Cruiser 2007 & on
07 fj oil filter?
Old Jul 13, 2006 | 07:51 AM
Firefightertaco's Avatar
Question 07 fj oil filter?
Today i went to get some oil and filter for my moms fj, i asked the guy what size filter and he said his compter didnt tell him, so i just asked what size was on the 06 taco 4.0L and got that one because arnt they the exact same?
Old Jul 13, 2006 | 07:58 AM
BT17R's Avatar
Yes. There's a little rubber plug under the filter funnel you'll need to remove before twisting the filter off. Put a cup under it to catch the filter drain oil. Be sure to replace the one-time use oil pan drain plug gasket too. It's the easiest oil change I've ever done.
Old Jul 13, 2006 | 08:18 AM
Is that oil pan drain plug gasket just a crush washer or is like a rubber gasket?
Old Jul 13, 2006 | 08:31 AM
BT17R's Avatar
Crush. I've used them twice without problems, but it should be replaced every time. It'll be stuck either to the pan or plug and take a flat-blade screwdriver to remove. Also check that the filter gasket came off with the filter or a double-gasket situation could occur = fire drill.
Old Jul 13, 2006 | 09:43 AM
How much oil do u put in yours when u change it with a new filter? i could look in the manual but im lazy.
Old Jul 13, 2006 | 05:46 PM
WillsFJC's Avatar
Mine seems to take almost exactly 5 quarts. It really is the easiest oil change you'll ever do. I love it.
Old Jul 13, 2006 | 06:31 PM
86SR522REEFI's Avatar
Yea. I get this all the time at work. Get a really small flat head screwdriver and scrape that sucker off. And always replace it.
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
ryerye13
Jul 14, 2015 08:27 AM
