Chevy spring swap question
Old May 29, 2006 | 10:17 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
I currently have my stock springs in, but I also have the shackles and mounts for the 63" chevy springs which I have in my garage. everything is already welded and all, its just some direct bolting to swap them out when i want to. the guy who did it though (previous owner) welded the front mounts about an inch too far to the rear of the frame. this causes some uneven lift in the rear. what would yall recommend for evening this out? is there something i can do the the leafs/shackles to lower it about an inch or some *cheap* way I can lift the front (by suspension) to level it? i've heard something about a spacer on top of the spindle but know nothing about it
Old May 29, 2006 | 10:48 PM
BajaRunner's Avatar
So your worried about having the rear sitting higher than the front?
Since you've already got 3" up front, you should go any higher there. Might want to try and use a shorter shackle. Ive heard there is a variation in amoutn of lift from the chevies depending on how long they had been used.
Old May 29, 2006 | 10:53 PM
yeah, rear sitting higher than the front. i can see shortening the shackles lowering it but wouldnt i have to shorten it somewhere along the liens of 2" if the axle sits in the middle of the springs? would that hurt my ride/flex ability a lot?
Old May 29, 2006 | 11:15 PM
garrett1478's Avatar
from the pirate FAQ:
Originally Posted by Chevy Spring FAQ
On 1998-2000 Tacomas mount the front spring hangers forward 7.5 inches.
that is the eye to eye distance. how far forward from the stock mounts are your chevy mounts?
Old May 30, 2006 | 08:10 AM
getitdone's Avatar
How long is your shackle? I am assuming you have installed them and that is how you know it's too big. What was your shackle angle?
You could try pulling out one of the chevy springs and replacing it with one or two stock ones. That might bring it down some. I think the optimum performance will suffer no matter how you try to "lower" it. If it were me I wouldn't touch the shackel, I would mess with the leafs, assuming you have a 45 degree angle.
Flying91
45
Apr 11, 2024 04:39 PM
Coreyr384
Jul 10, 2015 11:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
wilbertd
Jul 6, 2015 07:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
