Wireless Desktop
Linksys, DLink, and Netgear all make good stuff. Right now they're rolling over to the 802.11n technology, which should be out shortly but it'll be $$. You can get a good 802.11g router and equipment for lots cheaper.
If you're just using it for internet access, and not file sharing, then you won't notice a speed difference between b, g, or n. Well, that's arguable, but most say no. Only thing you might notice by going with "g" is a slightly better range. But "b's" have pretty good range too, and are dirt cheap nowadays.
Hope that's what you meant by your question.
From: Houston (home), Atlanta (school), Cincinnati (work)
What he said.
Extending on the "using it for internet" thing, you most likely have more of a "residential" connection such as Cable or DSL with speed probably around the range of 1.5 MBPS down. That is going to be your bottleneck there. "b" can support 11 mbps and "g" can support 54 mbps. With your connection being the bottleneck, you'll be running just fine. But like he said, for filesharing, you could possibly get the full 54 mbps...
talking about strictly connectivity range, G has a slightly longer range than does B, however, the range at which a G device can achieve maximum speeds (54 mbps) is much shorter than the full speed range of B.
Yup thanks guys that is exactly what I needed...
I am back for the summer from college and I brought my computer back... I will just use it for the internet... no file sharing really...
We'll my brother already bought a Belkin Wireless G Router 2.4Ghz-802.11g to use with his laptop upstairs... so I guess I will just use that also...
Suprarossa
Jul 6, 2015 05:21 AM
