Anyone with 17" OEM rims on a 3rd gen ?
Old Apr 18, 2006 | 06:42 AM
nrgetic99's Avatar
Anyone running 17" Toyota rims from a 4th gen 4runner or Sequoia on a 3rd gen ?
Seems a 265/70/17 or even a 75 would be a nice set up with a lift.
Anyone doing this ?
Thanks
David
Old Apr 18, 2006 | 06:56 AM
ebelen1's Avatar
I've seen a few including Kevin444 and Fuzion that run close to stock tires or Hoju that runs 35's on the Sequoia wheels. Kyle T has the 17" 4th gen wheels w/ close to stock size tires as well.
Old Apr 18, 2006 | 07:05 AM
nrgetic99's Avatar
265/70/17's run out at 31.7 while 275/70/17's run 32.4
However, about the only option in the 275/70/17 us a Radial Rover RXVT as the only other two made are Wranglers.
That may well be a hot set up. The only risk would be width issues.
David
Old Apr 18, 2006 | 07:06 AM
jethro's Avatar
Sgirt has 17" Sequoia wheels with 285/70/17 MT's.
Not the best pic, but all his pics are down.
https://www.yotatech.com/forums/show...6&page=1&pp=25
Old Apr 18, 2006 | 07:11 AM
nrgetic99's Avatar
Seems he had to shave his a-arms to run the 285/70/17's even with a lift as the side of the tire rubbed at full droop.
David
Old Apr 18, 2006 | 09:12 AM
KyleT's Avatar
Ido run OEM wheels, Lexus GX470 ones though, same dimensions as the 4th gen 4runner 17's. I also use a 1.5" bolt on wheel spacer.
Old Apr 18, 2006 | 09:31 AM
FilthyRich's Avatar
David
i have a set of stock upper a-arms with good balljoints. That way you can wait to install the shaved arms and won't have your truck torn apart.
I don't like wheel spacers either.
Also, 17" tires are more expensive than 16"
pm sent
Old Apr 18, 2006 | 10:47 AM
FUZION's Avatar
265/70/17
I would have gone to a 32.4 but I only have a 4cyl
Old Apr 18, 2006 | 10:12 PM
Jason B's Avatar
Your truck reminds me of my buddy's.
Old Apr 21, 2006 | 04:23 AM
nrgetic99's Avatar
Jason,
Is that the EVILTOYMAN rig ??
David
Old Jun 19, 2006 | 02:17 PM
WHORERUNNER's Avatar
is a spacer necesarry for those lexus rims, was there rubbing.
Old Jun 20, 2006 | 04:48 AM
93toy's Avatar
OEM size tire, no spacers.
Old Jun 20, 2006 | 04:59 AM
Rock Slide's Avatar
Now that's a sweet looking 4Runner 93Toy! Those Sequoia rims look good on that black sport.
Old Jun 20, 2006 | 05:01 AM
93toy's Avatar
Thanks!!
Old Jun 20, 2006 | 05:02 AM
MTL_4runner's Avatar
Ditto, very nice looking truck.....I almost got a set of those sequoia rims too, but the tire selection gets alot more limited (and expensive) when you move away from the 16" rims so I opted for the sport rims instead.
Old Jun 20, 2006 | 07:10 PM
AK's Avatar
AK
my 3rd gen on 2005 tacoma sport 17s. stock tires
http://pg.photos.yahoo.com/ph/alk130...e2.jpg&.src=ph
Old Jun 20, 2006 | 07:27 PM
So the 17's oem dont need spacers then???
Old Jun 20, 2006 | 07:28 PM
rocket's Avatar
mine...
Old Jun 20, 2006 | 07:29 PM
Also,I'm planning on the tundra 199mm brake setup. would these still work with 17's oem WITHOUT spacers.
Old Jun 20, 2006 | 07:30 PM
rocket's Avatar
^ yup.
