3rd gen 2WD brakes
Old Mar 28, 2003 | 06:45 AM
DrummerDaveB's Avatar
3rd gen 2WD brakes
My 98 needs some new front brakes, and I know the rotors at least need to be turned, cause I've got some obvious warpage.
What can I expect to pay for a brake job on this?
Im not willing to pay the premium the stealer wants to do it, so Im thinking more like Midas, or Olymco, or something like that.
Any suggestions on what route I should take?
Old Mar 28, 2003 | 08:56 PM
rpeAMP's Avatar
I use Brake Check (down here in Texas) to do my brakes. If you don't use the dealer, make sure to go to several shops and compare the prices. Brakes are a good way to get screwed (in my opinion).
BTW- When you get your brakes worked on/replaced, make sure to have the rears adjusted very often. This will keep them aligned properly with the 70/30 scheme. That way, the fronts won't have to work as hard (i.e. heat up under brake application) and warp the rotors.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
colasurdo
Jul 16, 2015 11:32 AM
