third member and diff question
third member question! help!
is my 93 toyota v6 4x4 IFS front third member/diff 7.5" or 8"? im not sure because when i checked the code on my door, i matched it with another website that tells you the codes, and it only gave me the rear size which is 8". also, whats the difference between 4cyl 8" and V6 8" third members/diffs?
any help is appreciated. thanks
Fronts are 'usually' 7.5" for your year model. Here's a link for more info:
http://www.off-road.com/toyota/tech/other/4_axles.html
Mike in AR
Mike in AR
Should have the 7.5 in the front.
The V6 rear has a heavier casting, gears, and I believe bearings. It does swap into a 4 cyl axle housing. I have used some of the charts that said a truck has a 4 cyl diff, but looking at the housing could see it was a V6 diff.
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
