New owner w/ squeaky 4Runner
Old Jan 13, 2006 | 02:38 PM
kev7706's Avatar
I'm a new member here as I just purchased a '99 4Runner LTD 4WD with 120K miles. So far I enjoy most things about it, but I have a question about a small issue I have. Whenever the wheel is turned to the maximum end (left or right), a fairly loud squeaking noise can be heard - but only for a moment. I suspect it needs some simple attention - like power steering fluid. I'm not mechanically inclined so please let me know what to do.
Old Jan 13, 2006 | 02:39 PM
Bob_98SR5's Avatar
sure its not screechy? most likely, its the steering stop noise you are hearing and yes, its normal
bob
Old Jan 13, 2006 | 02:41 PM
2001Millrunner's Avatar
sounds like a loose/old fanbelt.
Old Jan 13, 2006 | 02:44 PM
kev7706's Avatar
Bob: It sounds too loud to be normal. It's hard to describe the sound, but I guess it's not really a squeak. It's more like a whistle, I guess. I could be wrong - it may just be a normal noise. Thanks.
Old Jan 13, 2006 | 02:46 PM
kev7706's Avatar
Millrunner: I don't really know what a fanbelt is, but I'll check it out. Thanks.
Old Jan 13, 2006 | 03:54 PM
FORANA's Avatar
worn bumper stops? Metal rubbing on metal? Is it more pronounced when turning and going over a bump?
Old Jan 13, 2006 | 05:12 PM
kev7706's Avatar
The noise only occurs when the wheel is turned as far left or as far right as it can go while the car is in motion (such as when backing out of a tight spot).
Old Jan 13, 2006 | 05:17 PM
garrett1478's Avatar
sounds like steering stops. always happens to me when backing out of a parking spot.
Old Jan 13, 2006 | 05:26 PM
Bob_98SR5's Avatar
yes, then what youre describing is the infamous steering stop noise. and yes, its normal, so dont worry bout it
bob
Old Jan 13, 2006 | 06:36 PM
RockyMtRunner's Avatar
Infamous steering stops
I agree with the posters who suggest "steering stops." Try the following link and read the first part entitled, "First, the infamous steering stops . . ." It tells a way to prevent the noise with regular lubrication.
http://www.4x4wire.com/toyota/mainte...ront_end/lube/
Old Jan 13, 2006 | 08:29 PM
kev7706's Avatar
I followed the link and determined the infamous steering stops to be the problem. Thanks to all who responded.
Old Jan 13, 2006 | 08:31 PM
Beast's Avatar
IFS don't that
You want a solid axle!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 13, 2006 | 08:56 PM
kev7706's Avatar
I can only dream that I had a solid axle.
Old Jan 14, 2006 | 09:00 PM
kev7706's Avatar
The problem has been solved. Thanks to this forum it was a piece of cake.
ladybugRC
458
Aug 21, 2020 10:41 AM
smilen724
13
Nov 8, 2015 04:11 PM
Keithstoyota
Sep 27, 2015 07:29 AM
scheuvront1993
Sep 17, 2015 06:17 PM
