How to install Bushwacker Fender Flares??
I recently bought some used Bushwacker fender flares for my 2nd gen and need to install them. They didn't come with any hardware
Can somebody tell me if you are supposed to drill a hole, then install a plastic insert into the sheet metal and then attach the flare with a screw into the plastic insert (no metal to metal contact) like the way the original chrome fender trim pieces were attached, or do you just drill the lip of the fender and then use pan head screws to attach the flare directly to the sheet metal?
I'm planning on using #12 stainless steel pan head screws and bonded sealing washers from Fastenal. I have rust starting to develop in the wheel arches and I dont want the screw holes to rust out in a year or two. Any suggestions?
. Can somebody tell me if you are supposed to drill a hole, then install a plastic insert into the sheet metal and then attach the flare with a screw into the plastic insert (no metal to metal contact) like the way the original chrome fender trim pieces were attached, or do you just drill the lip of the fender and then use pan head screws to attach the flare directly to the sheet metal?
Bill - I *think* that those flares used existing holes. I had a couple of screws in them also (under the rear part of the wheelwell opening).
You can get the fasteners at Metric Screw and Fastener on Rt8 in Allison Park (412) 487-4989. I found the exact item that came with them. These things might be reusable, but mine were shot after being on for 8 years.
The parts are made by Auveco Products. I don't have a catalog, but I did find a pic of it on their site (called a "Push-Type Retainer"):
http://www.auveco.com/product.htm
Originally Posted by Bob_98SR5
PA,
why not contact bushwacker for the direcitons?
bob
bob
http://www.bushwacker.com/instructions/31907.pdf
Originally Posted by hill
Where did you get your flares from? how much?
Contacting Bushwacker would be too easy!!! Sometimes the solution is almost too obvious.
Mike,
I'm leaving for a meeting in Glenshaw now so I'll check out Metric screw while I'm up that way. Hopefully they have something in stainless steel.
Originally Posted by PAhydrohead
Bought them from Cebby used for I think $180 or was it $210, I can't remember right now.
Mike,
Mike,
Originally Posted by phorunninduke
Call bushwacker, I bought mine used and when I told them they sent out hardware right away. They have two different mounting styles too.
anyone else with used bushwakers for sale?
The seller has excellent communication and sent tracking number.
http://feedback.ebay.com/ws/eBayISAP...=STRK:MEWN:SID
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
The plastic screws that came with my bushwackers were crap. Bought some sheet metal screws. Drilled a few starter holes, installed screws, drilled rest of holes, took flare off, primed all holes, reinstalled flare, primed all scews again. Rust worries me.
Edit: Keggo, I'm telling ya, with little kids you can't get anything done on the truck quickly!! Unfortunately, working on the truck has to fall down the priority list below the kids.
