Clutch Install problems
Old Jul 2, 2002 | 11:06 AM
YoterTillDeath's Avatar
After a hard day of rock crawling I noticed a certain ratteling coming form the transmission area. It sounded like a T.O.B.(Throw Out Bearing), if any of you know what it sounds like read on so I figured what the hell, I'll upgrade the clutch while im under there. so I did the new centerforce went in without a hitch. The sound still persisted! now, when I engage the clutch the sound winds down and stops at any speed... Isn't the Pilot bearing Constant velocty, never stops? I did not replace the Pilot bearing... I know im a fool! I'm wondering if its my Sychnro's on the tranny? anyone have this problem or could help?
Old Jul 2, 2002 | 05:34 PM
Shane's Avatar
The only time the pilot bearing spins is when you have the tranny in gear and the clutch depressed. Are you sure this rattling isn't a loose heat shield or something?
Tranny input bearing maybe?
Old Jul 3, 2002 | 06:00 AM
Yoda's Avatar
If you can hear it wind down after stepping on the clutch, I would bet its the input bearing (like what Shane said).
And when you are back in there, put in the new throw-out bearing too. When you are working on your own rig, its a PITA to do rework, when you are working on a customer's rig, its a PITA to do rework and its free.
Old Jul 4, 2002 | 03:13 PM
Thank you for the advice. Looks like next weekend I'll be under the belly checking that input bearing. I did check the heat shield on headers and there were a few loose brackets and junk hanging on the exhaust/other places. I just tack welded those down with a hobby welder and it didn't cure the problem. Maybe this is a good time to re-build the T-Case to with lower gears I love repairing but I love moding too!
Thanks again guys!
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
bryan34w
Jul 6, 2015 05:53 PM
