What size speakers fit in 89 4Runner?
i have 6x9s but they dont have a real mount to them...i cut into the plastic between the roll bar poles.
Than i put dynamat on the inside of the panel... (NOT easy or fun to do) and made some wooden mounts for the speakers that go on the inside of the panel...
it worked out nicely...im running alpine type r 6x9s each getting 60watts RMS from my kenwood amp
The original speakers are 5 1/4.... I have made brackets for 6.5's to fit where the 5.25's went... still have them, but didn't like the sound of them. I then proceeded to make metal brackets for my 6x9's that i have now. all you need is a piece of sheet metal, and modify it.... I can walk you through it, or i can probably send you a template and some pictures... just let me know.
Thanks for the responses. Sorry about the dumb questions........I bought the truck but still need to go get it!!!
vmax84
Edited to add: Guess I'm putting the cart before the horse. Just excited about the truck.
vmax84
Roger that................I did talk to Crutchfield and they said it would be hard to get some big speakers mounted up in the rear of the 4Runner. He did mention boxing some 6x9's up, which I thought would be easy to do.
vmax84
vmax84
I made a bracket to hold my replacement 5 1/4 speakers. In retrospect I should have just upgraded to 6x9's but I orderd the speakers before I knew I'd have to fab the bracket
Notice the tabs on the top and bottom the bracket bolts to.
Erich
Erich
Erich, I did the same thing you did. I made a bracket for some 5 1/4's, then decided I should have just went with 6x9's. I yanked out the 5 1/4's, made some new brackets and put the 6x9's in. Much happier now!
icentropy
Jul 9, 2015 02:12 PM
