Diagram or list of the 3.4L pullys?
Old May 13, 2005 | 09:47 AM
li_runner's Avatar
Ok, 20,000 mile ago I had a private mechanic do my timing belt and tune up. 5k miles later the truck threws codes galore and started pinging. I then went to toyota to find that the timing belt had gotten loose and was wreaking havock because of a loose pully. They fixed the issue as I understood but there was some damage to a pully, they said it would work but it may in the future need to be replaced if this happened again. I want to figure out which pully (If I knew the pullys I could figure out which) needs to be replaced I think. So that I can ask if they have the part before I go and find out they don't after sitting in that great old waiting area for an hour
edit: After talking to several parts department, does the idler pully sound right? I'm trying to figure out all the pullys connecting to the timing belt.
Old May 14, 2005 | 03:49 PM
li_runner's Avatar
Bump no one knows the pullys on the 3.4? I hardly believe that.
Old May 20, 2005 | 09:38 AM
Wright's Avatar
3.4L pulleys
You have an idler pulley near the center below the cam pulleys and there's also a tensioner pulley located at the bottom left corner of the engine (looking at it from front). I'm attaching a pic.
djpg2000
Sep 7, 2015 10:36 AM
Badfish740
Sep 4, 2015 04:21 AM
Aaron Logan
Sep 3, 2015 08:08 AM
kelly1450
Sep 2, 2015 12:29 PM
