Oil leak help?!?!?!?
Old May 9, 2005 | 04:24 PM
.......Just put in a brand new 22re, drove form Vancouver to Seattle...... ran perfectly smooth and cool, get home and notice oil all down the passenger side and in the engine comartment. Never lost oil pressure......... I degreased the engine but can't find where it might be coming from. HELP!!!
thanks for your time............TIM
Old May 10, 2005 | 07:02 AM
.....the leak is coming from the front main seal areound the pulley shaft in front of the oil pump. the pump came installed from the engine builder! Is the seal bad or could it be a problem related to putting the shaft and pulley into it??
Old May 10, 2005 | 07:47 AM
PirateFins's Avatar
Seal could be bad, if the seal or motor sat around dry for a while. The shaft comes from inside the motor the seal, housing, pulley all slip over it. You might need to resleave the pulley if the shaft has grooves worn into it. Try a new seal and see if it stops leaking, its not hard to replace.
Old May 10, 2005 | 11:21 AM
Thanks!!!!!!! Got a new seal and repair sleeve so we'll see how this goes the second time around......
Gotta love yotatech.
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
