Anyone Have A Toytech Lift On An 05 Taco?
Considering getting the 3 inch Toytech with aal for my 05 taco.
Does anyone have experience with these guys and this product?
Has anyone put this kit on an 05??? Thanks!
I don't know but I do know that a few 4th gen. 4Runner guys are using the Toytec spacers in conjunction with an OME lift ... if the Toytec spacers work on the 4th gen. 4Runner, then they should also fit the 05 Taco because the front suspensions are the same.
Haven't installed it myself, but from the ToyTec pictures, it looks similar to Revtek 3" spacers in terms of the amount of preload and topout. Being 6061 T6 aluminium alloy, they should be very strong, not compress, and not rust.
The 05+ Taco front is similar to the 03+ 4Runner front. SOme people have run 4" lifts with no diff drop and no issues. ALso your ball joints in the front will be fine if you use a lift like the Toytec/Revtek or even OME front. Below is a pic of my CVs with 3 1/4" lift with OMEs and some other stuff.The new frot starts like 2" lower than the previous generation so you can lift higher (need to to get the sam eground clearance)
FS[PacNorWest]: 1992 4runner - 5VZ swap - Lifted
Swim
9
Jan 4, 2016 10:47 AM
Crgrey42
Aug 10, 2015 04:23 AM
ripp96
Jul 31, 2015 11:14 AM
