How much more will my tires stick out with this setup?
Old May 3, 2005 | 03:54 PM
Crux's Avatar
'97 4Runner 265/75/16s with Andy's Tundra/OME Lift + 1" BL (coming soon)
From what I've found (through lots and lots of reading and searching) the stock wheels on my 4R are:
16x7 with 4.375" of backspacing
If I were go to go to 16x8 wheels with 4" of backspacing
and 285/75/16 tire, would my tires stick out 1.375" more than they do now?
(1" from wheel + .375" from backspacing?)
Also, with the lower backspacing number (4" vs 4.375"), will I have less problems with rubbing suspension components and the fenders?
This is all new to me, so I'm still trying to get a handle on it all.
Thnx a bunch!
Old May 3, 2005 | 04:00 PM
Crux's Avatar
Doh, nevermind- I found a perfect example on Roger Brown/4Crawler's site (of course )
As an example, take a vehicle running 31x10.50 tires on 6" wide rims with 3.5" backspacing. It the wheels/tires were change to 33x12.50 tires on 8" wide rims with 2.5" backspacing, you would see the following changes in trackwidth:
Tire width: 12.50" - 10.50" = 2.0" wider or a 1" increase in track
Wheel width: 8" - 6" = 2" wider so 2" increase in track
Backspace change: 3.5" - 2.5" = 1.0" less so 1" *increase* in track
Adding the above 3 changes means the outside edge of the wheel/tire is 1" + 2" + 1" = 4" farther out from the vehicle (on each side) or an 8" increase in track
On the inside of the tire, you gain 1" of additional clearance with the backspace change but lose 1" of clearance with the additional tire width, so the inside edge of the tire should remain in the same plane as the current tire
Tire height: 33" - 31" = 2" taller, or a 1" increase in ground clearance and a 1" decrease in tire-fender clearance
Old May 4, 2005 | 01:44 AM
jimbo74's Avatar
should be fine... but... although making it wider like that, might make it less susceptible to rubbing the arms and suspension wider will make it mroe likely to rub the rear part of the fender @ the firewall
Old May 4, 2005 | 07:31 AM
Flamedx4's Avatar
You are thinking along the right lines though, the RIMS would stick out 1.375 more. The tires would be an inch wider (roughly) so add the half inch for them and you have 1.875 more sticking out. On the inside, giving the extra .375 of clearance, but using it with 1/2" of tire helps to not rub on things. Sounds like a great tire and rim choice.
Old May 4, 2005 | 09:02 AM
Crux's Avatar
Ah yes, i forgot to add in the extra tire width.
I suppose if it does rub a little I can always pound that pinch weld flat or do some trimming.
I really appreciate the replies, helps keep me on track
Old May 4, 2005 | 09:32 AM
dbikeman's Avatar
I went to a setup similar to that on my old truck and it really made a great improvement in handling too. The truck felt much more stable with a wider stance.
82yodahickman
34
May 16, 2017 01:00 PM
Cabell
Jul 24, 2015 12:14 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
crashburnoveride
Jul 10, 2015 06:39 AM
