brake job rotor turning question
Old Apr 12, 2005 | 07:41 AM
88FJ62-Cruiser's Avatar
brake job
Old Apr 12, 2005 | 07:52 AM
blink's Avatar
if you dont have any vibration problems when you brake, or if the rotors seem like it has grooves in it (test it by runing your fingers fro mthe center outward) then you should be okay. You are more likely to warp the rotors prematurly when they are turned because now there is less mass to disapate the heat.
Old Apr 12, 2005 | 07:56 AM
ugadawg95's Avatar
Get em turned...they may not be too bad now...but what's $15 in the grand scheme of things?
Old Apr 12, 2005 | 09:01 AM
MTL_4runner's Avatar
I turned a few sets and they keep warping soon after.
Now I toss them as soon as they warp and buy new ones.
Old Apr 12, 2005 | 09:17 AM
getitdone's Avatar
Turn the rotors.
If they are not perfectly flat, and they're not, then the new pads that you put on will magnify the grooves and your brakes will wear out prematurely. Always turn the rotors when you get new pads.
Old Apr 12, 2005 | 03:45 PM
TACOMANATOR's Avatar
My expierience has been that most rotors are throw away items now.You can turn them but they might warp, and when they warp your going to have to take your calipers off to replace them(another trip to the stealer). If they are glazed I would turn them, if not don't bother.
Old Apr 12, 2005 | 03:49 PM
jimbo74's Avatar
bear in mind that if you get decide to get them turned, there is a chance that they are below the minimum machining specification and they will need to be replaced, this wont come about until after they already have the truck apart where they basically have your balls in a vice at that point......
weakyota91
Jun 3, 2007 07:20 AM
Gangus2006
17
Jun 17, 2005 03:44 AM
Metricsocket
Apr 6, 2005 10:18 AM
CLin9383
Nov 28, 2002 06:48 AM
