Help, my 4Runner's bleeding
Old Apr 3, 2005 | 05:25 PM
Legacy 4Runner's Avatar
I've got an 89 3VZ-E engine with 196,500 miles and nice red puddle of coolant leaking. I suspect it's the water pump and I want to change it but it does not look too easy, nor does the "chiltons" give you good instructions. Anyone have better instructions in changing out the water pump???? Thanks in advance.
Old Apr 3, 2005 | 06:23 PM
gwhayduke's Avatar
Might as well do the timing belt and check your idler pullies out at the same time. You have to pull the radiator, alternator, powersteering pump, and crank pully. Take your time, put all the bolts in labeled ziplock bags and make sure you use a Toyota timing belt.
Here the manual for my '95. Most of it is the same, but your tensioner is different on the '89.
Good luck!
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Whatever123
Sep 30, 2015 12:12 AM
