Fan Clutch Question 3.0 V6
I'm reassembling my motor after a full rebuild (spun bearing) and am trying to determine if my fan clutch is bad. It takes about as much torque as opening a new jar of spaghetti sauce to turn the drive plate while holding the fan still. Is this normal, or is the fan clutch frozen. It's about 55 degrees here. Thanks.
A clutch fan is supposed to have some resistance when you try to turn it by hand. If its too smooth and easy to push than it too hard. But i guess temperature can also take its toll. Only way is just to turn it on and find out.
When I replaced my dead one two summers ago, I had the new one and the old one on the garden wall next to each other. The resistance to turning was identical--spaghetti jar is too stiff a description, but it was 90°F then. So yours could still be bad--or good. The roar on start-up that goes away is the best indicator, in my opinion, of a healthy clutch. I agree there is no way to be sure off the truck.
the1998sr5
15
Jul 14, 2020 08:35 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller
coryc85
Sep 9, 2015 06:24 AM
