30x11.50x15 on a 15x8 rim
Old Mar 14, 2005 | 06:50 AM
callmej75's Avatar
I was checking out the swampers and was wondering if a 30x11.50x15 would fit on a 15x8 rim? Says on the tire chart it is calling for 15x10 but I have a 10.50 on a stock 15x7 rim now. If I went with a 15x10 could I fit them on a stock 4runner with no lift?
Old Mar 14, 2005 | 03:20 PM
Paul H.'s Avatar
Yes you can. when I bought mine, it had 15X10's on it, switched to 15X8 because the tires stuck out way to much for my taste. 11.50 tires should fitan 8 inch rim with no problem.
Old Mar 14, 2005 | 03:23 PM
callmej75's Avatar
thanks paul! i might go with the 15x10's because i like to see the mud fly!
Old Mar 14, 2005 | 03:31 PM
terryjmatthew's Avatar
It will be quite a bit easier to pop a bead w/ a wheel that wide.
If you want to sling the mud, then get a wheel w/ a higher offset.
Old Mar 14, 2005 | 06:17 PM
kyle_22r's Avatar
i wouldn't recommend a 15x10 for anything under a 13.50 tire, more like a 14.50. 15x8 is perfect for 11.50 tires...i have them on my truck(31x11.50R15)
Old Mar 14, 2005 | 06:22 PM
callmej75's Avatar
Do you have any side pics or anything other than your profile pic kyle? would like to see what they would look like....was thinking hard on getting the 30x11.50 swamper tsl/sx. i know they howl and i probably wouldn't get the mileage that i would out of a radial but when i get the chance i go out muddy back roads here in virginia and west virginia and when i occasionally hit a nice hole i want to have a little grabbing when i go slamming through it. not worried about noise or wear....i want something to play in!
Old Mar 17, 2005 | 02:24 PM
callmej75's Avatar
Ordered 4 31x11.50x15 swamper tsl/sx's and 15x8 mickey thompson classic 2's today and everything will be here monday so I will post pics after they are on. Found out they discontinued the 30x11.50's because it was an odd size and noone was buying much of them so they bumped them up to 31's.
1uzRunner
63
Nov 10, 2018 03:58 PM
Cycles
Sep 29, 2015 06:37 AM
Bill McBride
Sep 20, 2015 02:51 PM
theduck21
Sep 10, 2015 07:01 PM
AkitaDog
Sep 3, 2015 09:01 PM
