idler arm rebuild
Old Jan 16, 2003 | 10:58 AM
Churnd
Guest
Posts: n/a
idler arm rebuild
my idler arm needs rebuilding and i'd like to do it myself but i'm kinda hesitant to try it. anybody know how hard it is to do the job? i saw the writeup on 4x4wire and it doesn't look that difficult but i'd like to hear from somebody who's had firsthand experience. one more thing... how do you remove a cotter pin? i've never done that before. thanks for any replies.
also, is it possible for the pitman arm to wear out? i've heard it's pretty indestructable but just wanted to be sure.
Old Jan 16, 2003 | 11:09 AM
DH6twinotter's Avatar
Re: idler arm rebuild
They usually pull out of the hole they are in. You may have to knock it out with a hammer (is that recommended?). I had one on a bike rack that was pretty stubborn sometimes. Hammer worked good. You could probably pry it out with a screwdriver too, if you had too. Try pulling it with your hand first though. Where is the pin located at?
I've never heard of a pitman arm going out. Then again, I'm not much of a mechanic either.
That's about as much of your questions as I think I know.
I'd like to rebuild mine too, so I am also curious on the responses you get.
Well, have fun.
DH6twinotter
Old Jan 16, 2003 | 12:48 PM
AgRunner06's Avatar
I just rebuilt my idler arm on my 4Runner. It wasn't all that difficult, but I would say that you need to be somewhat mechanically inclined. I used this write up here. It was very helpful.
If you decide to do your idler arm, I suggest that you use an air chisel with a fork in the end of it. My idler arm was really stuck on there and we couldn't get it off with just the fork and a hammer. After you take it apart you need to make sure that it is cleaned really well. Mine had apparently leaked and had some rust inside of it and on the shaft. Replacing the bushings and seal is the easy part.
Good Luck.
_Nicco_
Sep 21, 2015 03:06 PM
Gravel Maker
RuffStuff
Sep 8, 2015 05:46 AM
--Oz--
Sep 6, 2015 01:06 AM
ptb12
Jul 5, 2015 01:49 PM
