Timing Belt
When should I change the timing belt on my truck? It's a 95 Tacoma, with 90,000 miles on it. Is there a standard mileage when I should change it or is there a better way to know when it needs to be changed? I obviously don't want to wait until it's too late but I don't want to change it before it's time either. Any advise would be greatly appreciated.
I change mine every 90k because I have never seen one break before that.
Over 100k and I would begin to question when it will go.
Thanks Jamie. I just bought the truck. Is there any way for me to tell whether or not it's been replaced?
If not, I would assume it was not done (you can't tell just by looking at the belt).
Originally Posted by MTL_4runner
They should have put a sticker on the timing cover stating the mileage it was replaced at if they did it.
Basically, the same rules apply for checking the timing belt vs. any other belt. I'd stick with the manufacturers interval. When you do replace the belt, go with a GOOD quality belt. My 2 cents.
-Wrench
From: Far western Kentucky (transplanted from central PA)
Toyota recommends replacing the timing belt at 60,000 miles for the 3.0L engine. When I had my '90, I replaced the timing belt every 90,000 miles. While it was torn down, I replaced the water pump too. Cheap insurance...
