85 4runner radio wiring diagram
Old Jan 31, 2005 | 08:50 PM
Poopy's Avatar
I just bought this 85 4runner and apparently the radio was stolen(wiring harness ripped to ˟˟˟˟). Does anyone have or know where I can get the wiring diagram so I can install a cd player.
Thanks, Poop
Old Jan 31, 2005 | 10:40 PM
Poopy's Avatar
anyone? I'm tired of singing to myself, I really suck.
Old Jan 31, 2005 | 11:18 PM
the_supernerd's Avatar
Take a test light and start checking wires.
One will always have power
One will have power when ignition is at "ACC"
One will be a ground (probably black)
There might be a wire attached to the dash lights
For the speakers, try looking at the wires attached to the speakers and then find the same wire for the stereo. You could also touch a 9v battery to similar wires to find which speaker makes a sound. Then you would probably have to use an ohm meter to figure out which is negative and which is positive. Maybe even touch the wires to the 9v battery and if the speaker pushes forward then whatever wire is on the battery positive is positive. Do this after you have figured out the power wires so you avoid issues with the 9v battery.
By the way, welcome to YotaTech!
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
Jdgarrison
Oct 1, 2015 05:22 PM
toyota32
Jul 6, 2015 05:42 PM
ptb12
Jul 5, 2015 01:49 PM
