Sqeeky Stearing wheel
Old Jan 17, 2005 | 01:24 PM
brendonv's Avatar
on my 87 p/u, when i turn the stearing wheel it squeeks...is there a bearing in the column that could be replaced? if so, how do u get it out, do you need a press?
Old Jan 17, 2005 | 01:42 PM
884runner's Avatar
grease or graphite the little shaft that completes the horn circuit. the sound you hear is that part which is spring loaded rubbing on teh back plate of the steering wheel. simple fix
Old Jan 17, 2005 | 01:49 PM
BeaterToyota's Avatar
When my '88 had a bad squeak in the steering wheel it was because of some of the horn components.
There is a metal ring on the backside of the steering wheel that rotates with the steering wheel. On the steering column side there is a spring-loaded contact that presses against the ring on the back of the steering wheel. These two pieces making contact is what gets the electrical current to and from the horn button. The metal on metal contact was making the squeaking sound, especially when it was cold outside.
Get some dielectric grease from the parts store and smear some on. That fixed my problem.
Old Jan 17, 2005 | 01:52 PM
brendonv's Avatar
thanks for your help, glad its something simple this time
Old Jan 17, 2005 | 01:59 PM
It's real easy to get to. Just take off the plastic housing around the steering column and you can get to it.
Old Jan 17, 2005 | 06:12 PM
the_supernerd's Avatar
Mine used to do the same thing. It turned out that it is this plastic piece in the engine compartment. Follow the steering shaft and it is located just before it attaches to the steering box. Some WD-40 should stop the squeak.
Old Jan 19, 2005 | 04:02 AM
brendonv's Avatar
thanks, greased the horn, all fixed
kouki420
Sep 2, 2015 11:42 AM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
skoti89
Jul 6, 2015 07:45 PM
