Wil 32x11.50 Tires fit?
Will 32x11.50 Tires fit?
Ok the deal is i only have enough money to buy either my tires or my lift. The fact is i need tires NOW, because im practically on racing slicks... The thing is i am planning on going with 4" suspension lift, but it is stock height right now. It has bald 31x10.50r15 kirkland AT's now, and i want to go with 32x11.50r15 BFG AT's, and eventually after the lift and regearing, 33x12.50r15. Anyways, my question is, will i be able to fit the 32x11.50's with no problems being that i have no lift? There is plenty of space in the wheel well with the tires i have now. Will i need to just perform the pinch weld mod? Whats the deal?
Here is a pic of the truck to kinda show the space in the well available:
Thanks...
Thanks...
Maybe a little tbar crank. I've even seen guys do 33's. If you do 33x10.50 like me...you might be safe. A little tbar crank and a shackle or lift block in the rear(Cheap) and you should be able to fit 33's.
Flying91
45
Apr 11, 2024 04:39 PM
djpg2000
Nov 11, 2020 04:56 AM
coffey50
Jul 28, 2015 10:55 AM
