Idle Screw 95 Taco
Old Dec 23, 2004 | 02:36 AM
pat2724's Avatar
Idle Screw 95 Taco
I need to turn up the idle on my 95 Tacoma 2.4 automatic. It needs to go up when the truck is warm. Where is the idle screw? Any pictures?
Thanks
Old Dec 23, 2004 | 06:11 AM
Johnboy's Avatar
Isnt it near the front right of the cylinders? I wish I had a digital comera I would just snap ya one but I dont until the 25th. Should only need a flathead for it. Why you turnin up the idle?
Old Dec 23, 2004 | 06:33 AM
pat2724's Avatar
It just idles a little low when warm.
Thanks
Old Dec 23, 2004 | 06:50 AM
4Hummer's Avatar
https://www.yotatech.com/forums/f2/idle-high-heater-weird-problem-42152/
Right here. had allmost the same problem
Old Dec 23, 2004 | 09:08 AM
pat2724's Avatar
I found it now witch way I am guessing counter clockwise to raise it..
Old Dec 23, 2004 | 03:43 PM
superjoe83's Avatar
the idle is controlled by the ECU via the IAC, i wouldn't mess with the screw, its factory preset, what rpm is your truck idling at now?
Old Dec 23, 2004 | 04:13 PM
Bigblock's Avatar
Is the A/C on or off? The idle screw is on the throttle body. Adjust it first with the A/C off, then with the A/C on. It should idle between 700 and 1000 rpm either way. By the way, there is a separate screw for the A/C idle rpm.
87blyota
Aug 23, 2015 03:57 AM
rodskwad
Aug 12, 2015 02:33 AM
rap2me
Aug 11, 2015 05:03 PM
mtc1105
Aug 4, 2015 08:06 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
