No, my truck is not haunted...or...why my stereo comes on when battery disconnected
This is a funny story...funny for you all, not for me. It is kind of long, but be patient, you all should enjoy it.
A few months ago I pulled my starter out to replace the contacts. As safety requires, I pulled the negative terminal to my battery and went to work. We lived near a busy road and near a flight path to Seatac airport at the time, so at first I did not notice the music from the neighbors house. As I worked an listened more I realized that it was the same station I listen to, which was funny, because I never knew them to like that kind of music. A few minutes later I walked past my opened driver's door and realized the music was coming from my truck! I went back to the battery to make sure the negative was not contacting the terminal...all was good. Sheepishly, and totally confused, I reached in and turned off the stereo, which should have been off anyway. I started having visions of little gremlins living in my truck. I finished the project and went on with my life, never hearing a good explanation for the haunted stereo. Maybe we lived on an old Indian burial ground?
We moved a few months later. Yesterday I went to work on the truck, getting it prepped for tomorrow's trip to Tahuya. I disconnected the battery to remove it and replace it with a new one. I disconnected all connections to the battery and guess what? Yep, the stereo came on. I don't know if I can sufficiently explain just how stup and utterly confused I felt, standing there looking at a completely disconnected battery while listening to my stereo play music. I pulled the battery from the engine compartment and the stereo stopped...the gremlins apparently live in the battery, maybe they like the warmth or something.
I put the new battery in and, as I started to tighten the hold-down, everything came into focus! I use a top/side post battery. As the hold-down on my '91 is tighten down, the is a small barcket on it that bredges between the two side terminals, carrying a charge down the long j-shaped bolt and into the body of the truck! Ureka! Scott Richter-Super Genius! (Well, not really, but I felt pretty good about figuring this out!)
Moral: If you are having battery drain problems or your stereo turns on when it shouldn't, check your battery hold down to make sure it isn't bridging between the terminals!
alfonz33
9
Nov 16, 2015 09:21 AM
bigblue82
10
Jul 6, 2015 08:27 AM
