new clutch noise
Old Oct 2, 2004 | 04:57 PM
SlimJim248@earthlink's Avatar
new clutch noise
I have an 89 pickup 2wd and I just replaced the clutch cover, disk, throw out and pilot bearing. Ever since I did that when I drive it clicks. It speeds up with the engine, but when my truck warms up after a while, the sound seems to go away, but comes back after it sits. It sounds like a loud valve noise, but it has to be something with the clutch since it started when I replaced it. It only happens when I am on the gas though. I am hoping maybe it will go away. Anyone had this happen, Thanks in advance.
Old Oct 3, 2004 | 06:30 PM
Unhappy99's Avatar
If I recall correctly, the exhaust pipe bolts to the left side of the bell housing, and just above this is a pipe joint to the exhaust manifold.
Its leaking at or near this joint.
Old Oct 4, 2004 | 10:16 AM
Yeah, thanks for the reply, that is what it was and I found it right after I posted. The bolts were tight, but I guess they needed just a little more. Thanks
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
lmobeats18
Aug 28, 2015 04:57 PM
Dakotaneu
Aug 15, 2015 07:24 AM
norcal98
Aug 10, 2015 06:20 AM
PlayAwhile
Jul 20, 2015 11:36 AM
