Summer's Bro's axle kits
I don't know if anyone is interested or not, but this will help all those that had their axles pulled out from the front diff.
I just contacted Summer Bro's (Ole) the guy that helped the first time around and he said he could do some axles plus adapters for around $500. You will still use your outer CV though. It is very easy ( albeit messy) to take apart the axles and put this kit in.He also said he can make the axles any length you want, so you don't need to have an extra travel kit.AND he said if we can get ten sets going he'd knock off 18% each kit.
Oh yeah I think Mckenzies or BMW guy said the CV's run $49/ea I think the BMW's run $26/ea if I remember right they are just 1/4 " thinner than the Porsche's
This is the same kit for a grand:
http://www.bajaconcepts.com/Toyota_4...nsion_kits.htm
Maybe I should have explained better. This will replace the inner CV that everyone seems to pulling out with a Porsche CV. It will not pullout because the splines are longer going thru the Porsche CV therefore it will slip kinda like a drive shaft. Plus they will take up to a 32 degree angle for those lifted trucks.
http://www.rockstomper.com/catalog/drivetrn/930.htm
or this writeup from my buddies Co. a long time ago. It even gives the install instructions for the axle kit.
http://www.brian894x4.com/WCORIFSINSTALL.html
jerusry
Oct 19, 2015 05:28 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
coffey50
Jul 28, 2015 10:55 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
