1nt3rc00l3r for a GENIII
Old Aug 7, 2004 | 02:02 PM
4rnr541's Avatar
I have never installed an IC and am wondering what type is best suited for a 97 4rnr with a GENIII S/C. Also can anyone give me pointers on installing this intercooler. I recon its goin to be a custome job all the way. Is it better to rebuild my heads of get new ones? Should i get new cams in the process?
this is the runn down:
TRD GEN III S/C
K&N COI
TRD headers
Cat back Exaust
Fuel injection kit from URD(the greates thing ever)
I obviously want to cool the air so i am lookin at an intercooler or a water injection kit and some head work if i need to.
THANKS FOR THE TIPS!!!
"WHEN YOU FALL IN THE BOTTOMLESS PIT YOU DIE OF STARVATION"
STRONGBAD(TGS)
Old Aug 7, 2004 | 02:27 PM
MTL_4runner's Avatar
TRD GEN III S/C
K&N COI
TRD headers
Cat back Exaust
STRONGBAD(TGS)
You can't run an intercooler with a TRD supercharger....only choice is:
1) Run the water injection kit with the TRD S/C
2) Change to a custom centrifical S/C and then you can run an intercooler
Old Aug 7, 2004 | 02:43 PM
4rnr541's Avatar
I know its a roots type supercharger which replaces the stock intake manifold. It would have to a liquid intercoller so the only place that I would have to put an intercooler is between the block/heads and the supercharger itself. i have heard of guys doing this but i am not to sure about it.
Old Aug 7, 2004 | 05:19 PM
oly884's Avatar
Guest
I've seen similar things done, and the consensus is that it sucks. It isn't worth the extra money because it barely cools the air. Like MTL_4runner said, either run the water injection kit show here or do a custom supercharger.
Also, to add, I believe that you are talking about a gen 2 supercharger, to my knowledge there isn't a 3rd gen supercharger for the 3.4 V-6's
Old Aug 7, 2004 | 05:28 PM
That type of intercooler is horribly inefficient which is why all who have tried it got poor results.....it is just not a sustainable system (ie the heat can't be removed from the incomming air quickly enough to make a difference). If you are dying to have an intercooler then save up your pennies and do the custom S/C route.
Old Aug 7, 2004 | 08:12 PM
4rnr541's Avatar
http://www.gadgetonline.com/Super.htm
towards the bottom you can read all about it, but i am sure this site is not new to you. this is THE AUTHORITY on things 4rnr
Old Aug 7, 2004 | 08:16 PM
4rnr541's Avatar
dont want one at all actually, in fact i am even going to get ride of my K&N FKPI system and put the factory back on. i read gadgets entire web site and it was very informative. thanks for the info
lo&sloSierra
Jan 6, 2009 06:40 PM
