88 p/u running rough
Old Aug 2, 2004 | 05:19 PM
diverdown's Avatar
i have an 88 p/u that is running rough, idle is very low, will stall at stops if i don't step on the gas. lots of black smoke. a couple of times it has run on after shutting off. I can smell gas often. i have checked the vacuum lines with starting fluid, no change. i changed plugs dist cap & rotor, air filter, no change. engine has 212,000 and have do major work on it. any ideas, i am open to suggestions.
Old Aug 2, 2004 | 05:22 PM
seaflea's Avatar
pcv valve and O2 sensor.
Also check all the codes for it. Sounds like it needs a timing chain too. Check the timing and see where that is.
Old Aug 2, 2004 | 05:37 PM
diverdown's Avatar
thanx,i'll checkout the timing, the timing chain is original, so that could be part of the problem, mine has a carb, a mechanic told me the carb was bad, but he had no explanation, i think he just wanted to sell me a carb
Old Aug 2, 2004 | 08:08 PM
AKennedy87's Avatar
Ya deffinetly do your timing chain. Get a steel rail off of ebay, i got mine for $52 with shipping.
Also I have 2 carbs sitting in my garage right now, one from a running 22R and another older one but I'll sell ya both for $100.
Sleaker
Aug 26, 2020 06:03 AM
chukarhunt
Dec 8, 2019 11:39 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
v_man
Jul 23, 2015 04:01 PM
