piaa light wiring problems ?? help please
Old Jul 30, 2004 | 06:50 PM
skinnyrick's Avatar
wiring help please!!!piaa light wiring problems
hey guys this is rick in md i just installed a set of 6252 piaa driving lights on my new 04 4runner the install went well and i tapped the switch wire into the highbeam 10amp fuse the only problem is the fuse stays hot when i switch to lowbeam and i cannot figure out on the new 4runner where to connect the switchwire so they only come on with the highbeam please help .thanks rick
Last edited by skinnyrick; Jul 31, 2004 at 07:01 AM. Reason: reword for more response
Old Jul 30, 2004 | 09:12 PM
94yotarunner's Avatar
if you're wiring them with a seperate switch, just wire them to something simpler like the corner lights or the low beams. Well, I say the corner lights on my 94 because it was just two wires, much easier to tap into. IDK about the lights on other gens. If you're not using a switch then nevermind, I would just get a volt meter, turn the lights on and look for the wire to tap into. You've just tapped into the wrong wire.
Charecter1
Nov 6, 2023 10:08 AM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
steve miller
Oct 10, 2015 01:40 AM
toyota32
Jul 6, 2015 05:42 PM
colinmil
Jul 6, 2015 04:03 PM
