I cant adjust my TPS (Pic on why)
Old Jul 8, 2004 | 02:58 PM
Maddog's Avatar
Ive followed instuctions from my haynes manual & from some other internet info & cant understand why i have this situation.
You see my Throttle assemble is upsidedown compared to anything ive have seen in the manuals etc.
I Cant possibly get Feeler gauges to gap the throttle stop because its under the springs & stuff(see pic)
http://img43.exs.cx/img43/8324/DSC00611.jpg
How do yours look, is the throttle stop on the top of this mechanisum
How can i accuratly adjust the TPS.
Old Jul 8, 2004 | 05:17 PM
AgRunner06's Avatar
Look on the other side of the intake tube. There you should see a spot where you can put your feeler guage. Thats what I did.
Old Jul 8, 2004 | 05:27 PM
ChickenLover's Avatar
Yeah, the throttle stop is on the other side of the t-body. Let us know how it goes. I just tried to adjust mine and I'm not sure if it's right.
Old Jul 8, 2004 | 05:50 PM
934rnr's Avatar
The TPS is adjustable. There is a black electrical peice on the other side of the throttle body that is the TPS. You loosen the screws and turn it slightly that's how you adjust the TPS.
Old Jul 8, 2004 | 05:55 PM
Goldrunner's Avatar
I found it difficult to adust the TPS on the truck, so I ended up removing the TB and adjusting it on the bench. Made it much easier and afforded me the opportunity to clean everything, just make sure you have a spare TB gasket.
matt
Old Jul 8, 2004 | 06:38 PM
Maddog's Avatar
Not on mine,theres nothing on the other side ecept for the Sensor itself.I wonder if its got anything to do with mine being Right Hand drive.
Old Jul 10, 2004 | 08:35 PM
Maddog's Avatar
Well things just keep getting better,....Not.I tried to ajust my TPS but i cant loosen it ,the bottom mounting screw is munted.some F*#@in Idiot has stripped the hex patten ,god knows how?.
My only optoin now is to remove the TB so i can get a good shot at it.but i dont want to do that right now,F*#@in Stupid Truck ,im begining to wish i never got thr F*#@in Thing.
Old Jul 10, 2004 | 08:43 PM
You think you're pissed now? Wait till you get the sumbitch taken all apart and you still can't get the ˟˟˟˟˟er adjusted right. Sorry, I know that's not helping, but it's what happened to me the other day.
Old Jul 11, 2004 | 06:54 PM
radrex's Avatar
It's almost impossible to adjust properly with the throttle body still attached.
Old Jul 11, 2004 | 06:56 PM
AgRunner06's Avatar
Mine was held on with phillips screws. Yes they were hard to break but I finally got it. Try hitting them with some penetrating oil and see if that helps.
Good Luck
Old Jul 11, 2004 | 11:19 PM
Maddog's Avatar
Good Luck
unfortunately that wont help as the phillips pattern on the screw head is now just a round hole.
Old Jul 12, 2004 | 05:16 AM
MTL_4runner's Avatar
Drill the heads off the screws, take out what's left with pliers and replace with stainless screws.
Be sure to add grease to the stainless threads because they may bind otherwise.
Gone Fission
Jan 12, 2023 10:34 AM
Blamalam
Mar 12, 2022 07:34 AM
Sidherish
Aug 3, 2015 07:17 PM
Gone Fission
Jul 31, 2015 03:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
