wheels Wheels... Decisions Decisions...
Old Jun 23, 2004 | 09:07 PM
wvuviv30's Avatar
I am thinking about getting new wheels... I am looking to get a 33x12.50R15.
The question is 15x8 or 15x10???
My 4runner is going to be used for about 75% highway, 15% gravel roads and 10% Trails. When on the trails, I normally run street pressure.
I open up a 4Wheeler Mag, and the packages are for 33x12.50R15 Mounted on 15x10.
Old Jun 24, 2004 | 01:58 AM
Cebby's Avatar
I'm running 8".
I had two reasons for doing this.
1. Narrower wheel keeps the tire a little more under the body.
2. Narrower wheel is protected more from carnage (more rubber in the way than on a 10")
Old Jun 24, 2004 | 09:54 AM
crawler#976's Avatar
I'm also using 8" w/ 12.5's- for the same reasons as Cebby. Kinda a poor man's beadlock- I've run at 4 PSI in snow and at 8 PSI in the rocks with out problems.
The only draw back is the tire crown is pronounced more, and at street pressure tends to wear the center of the tread faster.
Old Jun 24, 2004 | 02:18 PM
Flygtenstein's Avatar
12.5" wide MT/R on 8" wide Eaton.
It works well. Bead issues have been minimal.
If you air down low on rocks, I think you will be disappointed with a 10" wide rim, that sure is a lot of space for a little tire.
Old Jun 25, 2004 | 08:22 PM
backyard_motorsports's Avatar
ive got 10's on my taco, and also running 31 x 10.5 , they look ok, i dont have a live so they ru b a bit when turning, i didnt read your signature to see what u have as far as your rig, lift and etc. but i love the stance the 10's give, i also drive high way 95% good luck on choosing
Old Jun 27, 2004 | 04:49 PM
Shane's Avatar
10 is what's usually recommended but 8 works better.
Old Jun 27, 2004 | 04:51 PM
jimbo74's Avatar
i work in the tire industry and an 8" wheel is actually the prefferd choice of real wheelers that are running 33s... 10" rims normally dont come into play until you are using them on a heavily modified truck with minimum of 35s on it
crammit442
7
Nov 29, 2017 12:30 PM
NCRidgeRunner
Aug 13, 2015 04:11 AM
Up&Down
Aug 5, 2015 06:20 AM
nonstop
Jul 24, 2015 06:29 PM
skoti89
Jul 6, 2015 07:45 PM
