Do all new rotors come with some kind of coating?
Installed my new Brembo rotors a couple days ago, along with some performance friction pads. I just opened up the box, and put 'em on, but I do remember it seemed like there was some sort of grease or coating on the rotors. Sure enough, brakes really sucked when I went to test it out.
I pulled out the pads, blasted them w/ some brake parts cleaner, and now all is well.
Is this normal for new rotors, or am I just unlucky (and/or stupid
)Last edited by mt_goat; Jun 4, 2004 at 05:09 AM.
Originally Posted by mt_goat
I think most have a anti-rust coating, something like cosmoline. Once you get oil or grease on your brake pads they are trash, you can't clean it off (or so I've been told). That's why it's so important to use brake cleaner on the rotor before you use them.
when I did my brembos a year ago I noticed the same coating. Its the oil they use to keep the rotors in good shape while thier on the shelves and during shipping. Blast it with brake cleaner and your good to go.
Originally Posted by bike4miles
Exposed steel will rust in just days without something on it. Any unpainted part will have some oil or coating on it to keep off the corosion.
Often times it is just the machining fluid left over from turning the rotors in the first place. If not as mentioned above, to prevent rust, but really a light rusting will wear off faster and hinder performance/safety much less than oily pads. Always blast 'em with brake cleaner and scour with scotchbrite or steel wool before installing.
-Sean
http://trailslesstraveled.com
-Sean
Originally Posted by 4RunnerFever
where did you get brembos for a 4runner? Do you think they are better than a stock 13 inch rotor? Thanks
86 87 4Runners
Sep 5, 2015 06:02 AM
mirabile4runner
Sep 3, 2015 07:15 AM
86 87 4Runners
Sep 2, 2015 03:54 AM
