2" or 3" ?
Old May 24, 2004 | 06:55 AM
motrhedx81's Avatar
2" or 3" ?
I've been pondering for a while and can't figure out if I need a 2 or 3" body lift. Either way its going to be an RB lift. I've got about 5" of suspension lift with the 4" kit and 1.5" rear shackles and a little cranking. My 35's fit fine but rub on susp compression and tight turning. Would a 2" lift keep me from rubbing on compression or do I need the 3" for that. I don't know if that extra inch of body lift would make it a bigger risk for rollover on a trail. I know the higher c.o.g. raises that risk and I have my tires set out pretty far for that reason. I guess my main question is; Will I see any rubbing with just the 2" BL?
Old May 24, 2004 | 07:56 AM
Flamedx4's Avatar
I have a 4" kit and a 3" body lift. My 35s will not rub - period. 37s did not rub normally, only in the most crossed-up stuffed-in mode... and only then once in blue moon.
Old May 24, 2004 | 07:59 AM
turboale's Avatar
In other words... 2 should be plenty
Old May 24, 2004 | 09:50 AM
motrhedx81's Avatar
cool.... thanks fellas
