Hey guys, I've a question about the new springs I'm fixing to try and install. One spring is marked with a "+" and the other with a "0". I've done some searching on the net and concluded that the "+" is supposed to go one the side with the most constant weight, presumably the drivers side. I called Rocky Outfitters, where I purchased these from and they could not verify this. I think I would have rather had both springs marked "0" since that is apparently right on spec. And since the gas tank on this truck is on the passenger side, would that negate putting the "+" spring on the drivers side? Any help is greatly appreciated.
