1988 22RE Engine Block Crack Repair Update Video
Sup guys, figured I'd post this here. I repaired the 5" long crack in my 22RE about 9 months ago. After 10k miles it is holding up perfectly still. Might be helpful to those who experience this similar common crack on the driver side of the block. Here is the original video showing how I repaired it:
Here is the update video:
Cheers
Cheers
The old Ford Flathead guys use the Irontite stitch weld or similar plugs like you used. It is definitely a good and proper repair. Many of the Flathead race engine builders also add Moroso Ceramic Sealer to further seal any cracks or leaking. Its added to plain water after a complete system flush for a few heat cycles I believe. Users say to follow instructions to the T and it is very effective. Thanks for posting.
'88 Toyota Daily
Jul 19, 2024 06:01 PM
