I just replaced the head gasket on my 91 22re about a month ago now it's blowing oil from under intake manifold area. Anybody know what it could be.
do you have EGR on it still ? or removed .. if removed , there is a bolt hole , in the triangle of bolts for the EGR valve directly into the head that needs to be blocked
I removed the EGR and all the other ˟˟˟˟ that goes along with it. I used the A.I. and EGR delete plates and bolted those in place and remove all the vacuum lines I didn't need anymore. https://photos.app.goo.gl/dAF77AEwS6U3bKsFA
