Subaru BRAT body on a 2nd gen 4Runner Frame. Wiring questions
So I'm currently putting a 1985 Subaru BRAT body on a 1994 Toyota 4Runner frame with a 3.0 and a M/T. I already have the body on the frame but I'm having some issues now that I'm putting the wiring harness back on.
I pulled the entire harness off of the donor 4Runner(don't worry the body went to someone making a crawler project).
So,now I have everything I have been able to find plugged in but I'm only getting a single click from the starter which I would normally just assume that it's a bad starter but my fuel pump isn't priming when i turn the key either which is leaving me a bit confused.
I finally found the FSM that's posted here and am about to go through my wiring connections again to double check that I properly attached my grounds and relays but figured I would ask here as well.
Any and all help is greatly appreciated
Okay so I've been able to get it to turn over now, not exactly sure what I did, except for reseat the fuses and relays.
Now my issue is no spark, gonna start chasing down the gremlins tomorrow. If anyone has an idea of where I should start feel free to shoot your ideas my way.
I know it's cringey but I actually have a little TikTok series for it if you're interested. I only edit videos when I have time though so it's a bit behind in the progress that I've made.
kawaii005
Nov 25, 2004 07:51 PM
