Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
NEW 16-22 Tacoma Sequential LED Headlights from FORM Lighting
Old Sep 12, 2022 | 12:40 PM
Form Lighting's Avatar
FormerVendor
Our Sequential LED Headlights are the perfect way to upgrade your 2016-2023 Tacoma. With these premium OE-grade replacements, you’ll add triple bi-LED projectors, sequential turn signals, startup sequence, LED running light, and a more aggressive, modern appearance.
Triple Projectors. What’s better than one projector? Three projectors. And in these headlights, all three are bi-LED units, providing output for both low beam and high beam illumination. With a sharp cutoff, broad width, and high intensity, these units provide a serious upgrade in output.
Startup Sequence. These headlights are packed with the latest and most modern lighting functions, including a startup or “welcome” sequence. Anytime the running lights turn on, they will illuminate in a two-stage chasing sequence that is sure to turn heads, with an ultra-premium look.
Sequential Turn Signal. The startup sequence isn’t the only thing that stands out. These headlights also feature a sequential switchback LED turn signal. Every time the turn signal is activated, amber LEDs activate across the top of the running light in a smooth, chasing sequence. When you’re finished making your turn, they automatically “switch back” to the bright white DRL.
OEM-Grade Construction. Form Lighting headlights are built with quality in mind, using OE-grade materials and design techniques. This includes durable UV-coated polycarbonate lenses, automotive-grade LED emitters, breather vents, and OEM plug-and-play connectors. You can rest assured that these lights will provide durable and superior performance.
Road Legal. Form Lighting headlights meet all SAE, DOT, FMVSS, and CMVSS standards and regulations for legal on-road use in the United States and Canada, when installed and aimed properly - which is easy to do with the integrated screw-type adjusters.
Plug-and-Play. Our headlights for the Tacoma are completely plug-and play and will fit perfectly, without any gaps. They were designed to plug into your factory headlight connector, with no wiring modifications needed. No errors, flickering, or hyperflashing! Adapters are also included to power the running lights, if your truck doesn’t come with daytime running lights (non-DTRL) from the factory.
Click the video below to see HOW to install our 2016-2023 Toyota Tacoma Sequential LED Headlights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. In the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Click HERE to check out our 2016-2023 Toyota Tacoma Sequential LED Headlights!
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: contact@formlights.com
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
Form Lighting
Old Oct 11, 2022 | 09:43 AM
FormerVendor
Prime Day savings are here! Ends midnight CST, 10/12/22.
NOW through 10/12, you can get 10% off at our Amazon store for Prime Day!
No coupon required.
This discount will be automatically applied.
Click HERE to visit the FORM Amazon store!
Old Nov 21, 2022 | 01:39 PM
FormerVendor
Our Black Friday Sale is here, and that means it’s time to save!
Now through 11/29, you can get 15% OFF FORM Lighting storewide!
No coupon required.
This discount is automatically applied.
CLICK HERE TO SAVE AT THE FORM STORE!
Old Nov 29, 2022 | 12:26 PM
FormerVendor
LAST CHANCE for 15% off LED headlights for your Tacoma! Form Lighting's Black Friday Sale ends TONIGHT!
No coupon required.
Old Dec 22, 2022 | 09:58 AM
FormerVendor
ONE. MORE. SALE. 🏷
Now through 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
This is your last chance this year to save on our LED headlights for your 16+ Tacoma!
Shop our Amazon store ➡ Form Lighting
Old Jan 2, 2023 | 11:12 AM
FormerVendor
There’s only a few days left to save!
Through midnight 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
Start your new year off right with some fresh headlights!
Shop our Amazon store ➡ https://amzn.to/3WlDQcv
Old Feb 1, 2023 | 11:42 AM
FormerVendor
Peep Those Tacoma Headlights? 👀
Check out our YouTube channel to see more!
Upgrade Yours Here!
Old Mar 6, 2023 | 01:01 PM
FormerVendor
The lowest prices of the season are HERE! 😱
Now through 3/13, you can get 10% OFF SITEWIDE at FormLights.com.
If you’ve been waiting for the best time to pick up a new set of headlights, the time is NOW!
Click here to save!
Old Jun 1, 2023 | 07:27 AM
FormerVendor
Have you been thinking about upgrading your headlights? NOW is the time to save BIG!
Memorial Day Savings are here at Form Lighting, which means through June 2nd, you can get 10% OFF sitewide.
Get yours before it's gone! ➡
https://www.formlights.com/
Old Jun 14, 2023 | 09:50 AM
FormerVendor
https://www.youtube.com/shorts/FDHSGC3YwX0
From front to back, we've got your 16+ Tacoma covered. 👊
Upgrade Yours Here!
Old Jul 3, 2023 | 11:52 AM
FormerVendor
If you've been waiting for the best time to upgrade your headlights- the time is NOW! 📣
To celebrate Independence Day we are offering 10% OFF SITEWIDE through July 7th. Plus, get a free FORM t-shirt with any purchase! 🎆
Get Yours Here!
Old Jul 7, 2023 | 06:20 AM
FormerVendor
The best time ⏳ to upgrade your headlights is almost UP!
10% OFF sitewide
ends soon! Get over to the site now to save up to $100, and don't forget with every purchase you will receive a free FORM t-shirt!
Get Yours Here!
Old Jul 11, 2023 | 09:00 AM
FormerVendor
The Prime time to Save is NOW ❗
For two days ✌ only 7/11-7/12 Save 10% on all FORM products.
Get Yours Here![/url]
Old Nov 7, 2023 | 07:08 AM
FormerVendor
Check out our NEW YouTube video covering the best lighting upgrades for your 2016-2023 Toyota Tacoma! 🤘💪
Old Nov 27, 2023 | 01:02 PM
FormerVendor
Save 15% across our entire website for Cyber Monday!
That means discounts on all our great products for the Toyota Tacoma!
These sales won't last forever so don't miss out!
Savings end December 1st
Click here to save!
Old Dec 1, 2023 | 11:03 AM
FormerVendor
Our BIGGEST sale of the year ends tonight at midnight! 😧
Your last chance to save 15% on Headlights and Tail lights for your Tacoma is NOW!
Don't miss out.
Take advantage of these sweet deals while you still can!
https://www.formlights.com/by-vehicl...ta/tundra.html
Form Lighting
Vendor Advertising
15
Dec 1, 2023 10:42 AM
Benson X
03+ 4Runner/GX470, & 05+ Tacomas (Build-Up Section)
Sep 30, 2013 11:28 AM
TRUCKDIVA
Vendor Advertising
Jun 18, 2013 12:28 PM
aQuarius26
Colorado
Jul 30, 2011 10:10 AM
aQuarius26
Jun 21, 2009 06:04 AM
