Power to Manual window swap
Old Mar 20, 2022 | 12:48 PM
68jimmy's Avatar
I take it you cannot swap a power window regulator for a manual type in an '89 4Runner SR5? Did Toyota really have two types of doors for power vs manual windows?
Thanks.
d.
Old Mar 21, 2022 | 07:50 AM
slacker's Avatar
no .. same door ...
all the holes are there . easy swap
I just went from manual to power
Old Mar 22, 2022 | 05:34 PM
68jimmy's Avatar
Thanks but I'm not sure what your door looks like but mine seems to be missing the necessary holes around the crank. Maybe its an '89 thing, it was an odd year. Here are a few pics of my door along with the new regulators.
Old Mar 23, 2022 | 07:23 AM
slacker's Avatar
your using the wrong holes , bottom pic shows where it goes .
Old Mar 23, 2022 | 09:03 AM
68jimmy's Avatar
Slacker,
thanks for your pics that helps. i was thrown off w/ my door where in my 2nd pic has the 4 gold bolts used with the factory power regulator. From what I'm seeing I'll use the two lower holes closet to the handle opening along with the upper rear. So only 3 bolts are used rather than the 4 I have?
i'll pull the door panel and take a look.
Thanks
Old Mar 23, 2022 | 10:05 AM
slacker's Avatar
your manual regulator dosnt look right though ? it should be only 3 bolt for a manual window not 4
/89 4runner is not the same as an 89 pick up . I think you have the wrong regulator , or maybe that just the way the aftermarket made it ?
Old Mar 23, 2022 | 12:41 PM
68jimmy's Avatar
Looking at yours I would concur. I purchased them from Low Range Off Road, they listed a number of Toyotas including my 89 4Runner.
Thanks.
whitetaco02
Aug 25, 2016 06:42 PM
redbayredneck
Nov 25, 2013 04:41 AM
xrecar
Jun 18, 2012 04:35 PM
nicksmith18vt
Mar 9, 2012 05:01 AM
Tacoma750
Nov 20, 2007 08:02 PM
