Sponsored by: CARiD
1999 toyota proprietary diagnostics tool
Old Aug 9, 2021 | 09:29 AM
99solara's Avatar
I noticed on my 1999 toyota solara there is a dedicated diagnostics port under the hood. Does anyone know where i could buy the diagnostics tool for that?
Old Aug 9, 2021 | 12:34 PM
wyoming9's Avatar
Red face
I think Snap On tools makes something for Toyota but your talking something that gets leased for the most part Dealerships and high volume shops
Back 20 Years ago The cost was 10 grand plus the yearly software up dates
This is off the Top of my head might be completely wrong.
Old Aug 10, 2021 | 12:19 PM
2ToyGuy's Avatar
I believe all the diagnostics tools available for toyotas are for the OBDII port in the cab. The one under the hood, by the fuse block, is the OBDI port, and I'm not sure there's a plug in tester for it. I may well be wrong on that though.
Everything I see in the FSMs, however, sure seems to point to jumpers and meters for using that test port. Again, I may well be wrong, though.
Good luck!
Pat☺
Old Aug 10, 2021 | 12:47 PM
millball's Avatar
The OP says his machine is a '99. Apparently it has a proprietary diagnostic plug in addition to its OBD II plug.
I know nothing of this double set-up.
I do, however have a SnapOn MT2500 scanner and associated adaptor plugs that fit the OBD I plugs found next to the under hood fuse blocks on my '87 and my '95 4Runners.
I remember that the '95 ECU will give out more information than the '87 will.
Been awhile since I've needed to scan either one of these trucks, but I remember that on the '95, I was able to read on/off idle TPS readings and set the TPS using the scanner.
The scanner was able to show other things like open/closed loop running status. Many more functions than merely reading set codes.
This scanner and its attachments and software did indeed cost thousands of dollars new, but its nearly obsolete now, and only sought out by nuts like me.
Old Aug 10, 2021 | 01:00 PM
wyoming9's Avatar
Red face
Good luck!
Pat☺
Not to be confused with a OBI test port
There is the high end tools( $$$$$) the Dealer uses that Can do all kind of interesting things that plug in to the test port under the hood my 2000 3.4 has the plug
These tools can duplicate and vary sensor signals on non running engines for trouble shooting problems
littlerunner
Apr 11, 2006 04:21 AM
2002 SportEdition
11
Aug 3, 2004 11:00 AM
4-RUNNIN' FREAK
25
Jul 13, 2004 05:57 AM
