Need new 1994 3vze auxiliary air control valve gasket
1994 Toyota 4Runner SR-5 3.0L A/T 4WD
Hey all - I had a surging and low sputtering idle when the engine was warm on my 1994 4runner. I took the TB off and cleaned it and also cleaned the aux air control valve with TB cleaner. Unfortunately - the 27 year old tear drop shaped rubber gasket for the aux air control valve cover shattered in my hand into a bunch of pieces. I need to buy a new gasket. Does anyone know this part number or any way to buy one of these gaskets? Autozone wasn't able to help me out here.
Here is what the aux air control valve on the 3vze TB looks like:
After much searching, it appears that Toyota does not sell that gasket. You could make your own out of the appropriate thickness of bulk gasket material, that is available at almost any parts store or online, like this:
I just lay the material on the parts and use a small hammer to gently tap around the inside & outside edges to get the shape down right, then use a ball-peen hammer to gently tap the holes to get an impression of them. Then I use either an Exacto-knife or razor blade to complete the cuts.
Here's the general idea:
