Dually brakedrums Itasca motor home
The rear end should be the Toyota HiLux 1-ton. It had beefier brakes and rear axles. Toyota only offered it for a few years. The were fed up with aftermarket companies buying the 1/2 ton, pulling the bed off, and overloading the heck out of it. Do the rims have "Toyota" on the bead? The rims were the giveaway. The spare tire would replace any of the 6 tires if you got a flat, regardless of the position(front/rear)
jef free....go to this site..its all about toyota motorhomes and can answer any question you may have.
http://toyotamotorhome.org/forums/index.php
I came up with Toyota part number 42431-35190(originally 42431-35130)
4unner4life
25
May 4, 2005 04:44 AM
