All Other Toyota Swaps I4, I6, Lexus V8
Stock 1993 pickup 2jzge swap
Old Oct 28, 2020 | 02:30 AM
Thomas Soucy's Avatar
Hello, I've been searching far and wide to try and find as much info as I can on swapping my 1993 4cl 5spd rwd toyota pickup to a 2jzge. Most of what I've found isn't exactly what I'm looking to do. Anyone able to point me in the right direction? Not looking to make crazy number just something fun to drive. Will the 2jzge bolt to my w55 transmission(think that's what the truck has)? Any help is much appreciated. Thanks
Old Oct 28, 2020 | 10:41 AM
Genera_lee's Avatar
from what i've read, you're better off finding an R series transmission to use behind it.
otherwise you'd likely need to fab motor mounts (the 7mge and 7mgte actually bolt in if you use the 22re pedestal and 5mge motor mounts - its possible the 1 and 2j are the same, bu i wouldn't bet on it), trans mounts, use the r154 or similar bellhousing to the w55 (2wd) or w56(4wd) trans chunk. clutch/fw have to be for the 2j.
exhaust and intake are on opposite sides of the 22re so that'll be an issue to deal with, as well as steering because of that.
then the full wiring harness for the 2j and figuring out how to splice in whatever functionality you want IF you run standalone. otherwise, you'll basically just have a speedo and maybe a gas gauge if you use the ecu from the 2j and keep the truck computer to run accessories. since its obd2 it wont play nice with pre-obd2 stuff in our trucks
i welcome being corrected on any of this, but from the research i've done on it (i want to do the same, but am leaning toward a 7mge) thats what it would take to get it done.
theres more than few threads on here where people have done it, or petered out. of the better ones i remember seeing was on a mini-truck forum somewhere. maybe that will point you in the right direction
Old Sep 4, 2022 | 05:55 PM
kulpio's Avatar
I am leaning towards 7mgte too
Hi!
I wanted to know if you went deeper in this swap? I am trying to plan doing the same to my ‘93 2wd 22re with w55 tranny. I am looking to estimate my BoL and what to expect 🫠
Thomas Soucy
Oct 27, 2020 07:16 PM
rammesees33
Jul 15, 2019 04:27 PM
Austin Marr
3.4 Swaps
Oct 11, 2012 12:05 PM
sorakiu
Jul 20, 2010 07:36 PM
